Old 01-04-2014, 03:25 PM
cubfixer's Avatar
cubfixer cubfixer is offline
Default How can you heat up a gen set in cold temps?
My gen set is a recoil start with an aluminum block. When it is really cold, it is very hard to start. If I could keep the oil warm, it would be much better. Now I use starting fluid, and 10w30 oil, but it would be better if I had some type of block heater. Magnetic heaters won't stick close enough to the block to transfer enough heat. Any suggestions?
John
Old 01-04-2014, 03:40 PM
Is it inside? Or outside? If outside, you could put a tarp over it with a heat lamp on it. If inside a garage, just the heat lamp and no tarp.
Old 01-04-2014, 04:48 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
http://www.tractorsupply.com/en/store/dipstick-heater
it may be too long tho, or what Jonathon said.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 01-04-2014, 05:49 PM
sawdustdad's Avatar
wolverine makes heaters that stick on the oil pan with adhesive.
https://www.wolverineheater.com/product-p/4.5.htm
Old 01-04-2014, 06:27 PM
Shrewcub's Avatar
That's pretty cool!!
All our ideas are great, if your home when the power goes out!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 01-04-2014, 09:55 PM
cubfixer's Avatar
It is outside under a tarp. Probably not enough room for a heat lamp. The oil fill is only about 2 inches deep. Maybe the heater with adhesive would work. Thanks for the advice!
John
Old 01-05-2014, 08:08 AM
A few more options for the heaters
http://www.amazon.com/s/?ie=UTF8&key...sl_4iaue225w_b
Old 01-05-2014, 11:31 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Kat's makes immersion/bayonet screw in heaters you could install into a NPT oil drain hole too. They advise 10 watts per quart sizing.
You might also be able to use a wrap around battery blanket (12V) or a stick on battery heater also.
Old 01-05-2014, 11:37 AM
Whats a gen set???
Old 01-05-2014, 11:50 AM
DoubleO7's Avatar
you know, an engine driven generator you drag around to where needed for 120/240 voltages.
