Old 01-06-2014, 07:34 PM
Flatbedford's Avatar
Default Ebay wheel bearings
Has anybody bought from this guy? Are these correct for my 3/4" spindle 149? They give metric size, not fractional.
http://www.ebay.com/itm/Qty-of-6-Cub...item540319b521
Maybe too good a deal to be true?
My crappy little MTD Cub Cadet cart goes through bearings pretty fast when I move firewood.
Steve,
Former multiple 149 owner.
Old 01-06-2014, 08:13 PM
macman81's Avatar
macman81 macman81 is offline
While the measurements seem close those are not the correct wheel bearings. The correct ones are fractional sized
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 01-06-2014, 08:18 PM
This is what I think you are looking for. Pretty sure I got this info from Roland when I was a newbie on OCC. But I'm old and have a bad case of CRS.
Old 01-06-2014, 08:28 PM
CTRUEX CTRUEX is offline
20mm is 1mm too big, and they would not last very long, if you could get them in, but 47mm is 1.85". The width doesn't really matter, the wider the better. The ABEC3 rating is the only good thing about them, other than the price, but they will not work.
Old 01-06-2014, 08:46 PM
Thanks guys. My quick research showed them to be too good to be true and you all confirmed. I'll look into the ones Sam Mac posted.
Steve,
Old 01-06-2014, 09:04 PM
This looks like the best price I can find so far.
http://www.easternia.com/heim-ungrou...ame=rf122214pp
I haven't found out shipping cost yet. I don't mind spending a few bucks if its good stuff.
Steve,
Old 01-06-2014, 10:37 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Default wheel bearings
I have bought these before.. They are a good high quality bearing. Currently running them in a 70 with no issues. seem to be alot better than the crappy low speed bearings that most sell.
http://www.ebay.com/itm/IH-Cub-Cadet...#ht_2350wt_855
Jay
Proud owner of the following:
Old 01-06-2014, 10:46 PM
TheSaturnV's Avatar
When I was looking at front bearings for my 147 project, I saw everything from $20 each on down to $1.50. At even $15 per, that's 60 bills just in front wheel bearings. I decided to be a test subject and went for the el cheapos. They turned out to be the Oregon packed brand and only time will tell just how long they will hold up. Should be interesting to see.
Old 01-07-2014, 10:32 AM
kostendorf's Avatar
I bought these bearings also 1 year ago and they work great. No complaints. Before these the bearings I was using would last a month of cutting grass and fail. Don't buy cheap stamped bearings, Get the machined ones. Remember your tractor weighs 700 plus pounds.
