Old 01-08-2014, 06:39 AM
Default Lubricants and Cold Weather
Seen these on another Forum and thought it was worth while and something to consider.
These video's are produced by Esso Oil of Canada.
http://www.youtube.com/watch?v=OWiQyR7PWII#t=0
http://www.youtube.com/watch?v=ETKECO86VS4#t=6
Old 01-08-2014, 09:10 AM
jimbob200521's Avatar
Just...wow
The part in the first video at about 2:20 where they dump the oil kinda scared me Makes me wonder if I should be running something lighter in my Cub's during these winter months.
http://youtu.be/OWiQyR7PWII?t=2m20s
-Ryan
Old 01-08-2014, 10:18 AM
Good post, lots of worth while info.
Old 01-08-2014, 11:23 AM
X2!
Old 01-08-2014, 11:47 AM
Thanks for sharing, Roland!
Old 01-08-2014, 07:25 PM
nikster's Avatar
nikster nikster is offline
What a great movie clip. Running a straight 30w oil does not hack it in cold, cold weather. Being thicker than molasses, it takes a long time to warm up & to properly coat the internal parts of the engine. Which means that the running engine is running dry. That means wear & tear.
That's why I use synthetic 10/30 sae30 small engine oil for instant lubrication.
Eg:
I ran out of gas &. My # 127 sat at the end of the drive this past monday, it was -12deg. below zero. Went into town got gas & did some shopping. By the time I got back it was about 2.5hrs. Later, filled it up & the engine cranked as if it was 40deg. Out. Didn't falter at all & felt good knowing the oil was instantly lubricating the internal parts of the engine on the 1st. Crank.
NIK,
Old 01-08-2014, 07:55 PM
cubs-n-bxrs's Avatar
Nik the 12hp Kohler is not a pressure lube system so it still takes a little time for oil to get splashed up on the rod. That is why I run 5w-30w synthetic in the winter for just that reason.
Old 01-09-2014, 08:41 AM
donnelly.me's Avatar
donnelly.me donnelly.me is offline
Well, that officially scared the crap out of me! I am running straight 30 and it gets pretty cold here in NE PA. I'm going to switch to something lighter today. Maybe a 5w-30? I also have a question though. What's the harm in running the lighter oil year round instead of just in winter? People run the mix weight oil in cars,trucks, ect. Thanks,Mark
1973 Model 149
42" Snow Blade
John Deere X360
John Deere 10 cu Poly cart
Squire Applegate 5HP recoil start
Old 01-09-2014, 04:05 PM
I run 30 wt in the summer and 10W-30 in the winter, both conventional grade. It seems to work; starts well when it's cold.
Old 01-10-2014, 09:33 AM
johncub7172's Avatar
Great video! But.....I sure won't be outdoors in -35* weather- sorry. That's a cold, cold, heart.
