Old 01-16-2014, 07:58 PM
smithviewfarm smithviewfarm is offline
Default Hydrostatic question
New owner of a 107. Tractor goes forward and reverse fine returns to Neutral when braking no creep. But today I noticed I could push tractor around when not running no matter where the locking lever was located so it is always in neutral. Is there something wrong with transmission or something not hooked up right? Should i just ignore this or could something be wrong or go wrong?
Old 01-16-2014, 08:08 PM
"IF" someone switch from the Manual Relief Valves to the Automatic Type, then that would be normal.
IF you have then Manual Type of Relief Valves, then I am thinking there is something wrong with these valve(s).
Old 01-16-2014, 10:27 PM
FWIW, I have a 105 that does the same thing, runs great, pulls fine, pushes snow and goes up and down hill as it should. It's been like that for a long time, it doesn't have the auto release valves. It also happens to be the one that leaves a little puddle on the floor.
I'll put a new gasket in it one of these days, but I'm not going to worry about the ease of rolling, until something no longer works. (not at all sure that is the right thing to do though)
Old 01-16-2014, 11:24 PM
FWIW, I have a 105 that also happens to be the one that leaves a little puddle on the floor.
That one must be a male cub Sam, 'cuz it likes to mark its territory!
Old 01-17-2014, 12:41 AM
Never thought about it before but you could be right, it's never been temperamental either...
Old 01-17-2014, 01:11 AM
cubfan's Avatar
cubfan cubfan is offline
Kinda like a Television with a good picture,don't mess with it.Yosemite Sam and Cub Cadet123 thanks for the chuckle.
Old 01-18-2014, 11:27 AM
IH Cub Cadet IH Cub Cadet is offline
Sounds like automatic relief valves have been installed. If so, the rolling is normal.
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 01-18-2014, 12:30 PM
I am clueless about these valves. Where are they located? Can I get to them?
Old 01-18-2014, 02:19 PM
They are under the fender pan on top of the hydro pump. This is the link to the manual.
http://www.onlycubcadets.net/forum/s...ead.php?t=4643
Old 01-18-2014, 05:14 PM
This will help...
