Am getting my 882D ready for the season and I noticed the Alt/waterpump belt and the radiator fan belt both look a bit tired. When I tried to figure out how to replace them it looks as if the engine has to be pulled.
The alt/wp belt has the driveshaft running through it, and the fan belt looks as though the electric PTO has to come off, which probably means pulling the radiator. Does anyone have any cunning ways round this, or do I just cross my fingers and hope the belts last a bit longer? |
Chris, you have to pull the driveshaft to change the alt/waterpump belt, its a PITA to do. For the front belt, you can remove the shroud on the radiator, then remove the mount that holds the fan itselt from the front of the engine block. That will give you the room to change that belt. My belts are not real pretty, but with my 782d only really getting used at plow days, I am running them till they are really bad. You might have to unhook the power wire on the front clutch, but looking at it, I think the belt will slip over it once you can get it past the fan for the rad. Mike
I decided to bite the bullet, as I use my 882D for regular mowing. I looked at those belts and I just knew that one was going to let go and I would have to replace it on an emergency basis, probably when it was 90 degrees and 100% humidity. The fan belt is relatively easy. You unplug the PTO wire and then remove the top bolt and loosen the bottom bolt on the piece that restrains the PTO from turning. You can then work the old belt out and put the new belt on. So far so good.
The alternator belt can be worked back into the drive tunnel, but you still have to break the driveshaft. I plan to undo the rear flex joint, which is readily accessible. If I find I can take the entire flex joint out, that will give me the room I need to pull the old belt and replace it. If I can't, then I will have to loosen the bolts holding the entire motor/radiator setup to the chassis and hope that I can get enough slack to let me replace the belt. Personally, I think this setup is Kubota's revenge for WWII. Will keep you posted. |
