Old 01-26-2014, 05:21 PM
The Old Cubby Hole The Old Cubby Hole is offline
Default Tiller for a 149
Which tiller fits my 149 and where can I get a rebuildable one?
Old 01-26-2014, 05:26 PM
A #1, 1A, and 2 fit your 149.
What do mean by rebuildable?
Welcome to OCC also!
Old 01-26-2014, 05:50 PM
I do industrial maintenance for a living and have a good size personal shop, so machining, welding, and general fabrication is not a big deal for me. I have never seen the setup for the tiller attachment so I'm not sure what all it intails but I'm always up for a challange.
Old 01-26-2014, 06:41 PM
Welcome to OCC!
No machine work required, welding or fitting. Tiller gearbox bolts on. Tiller mounts to it. If your tractor doesn't have a 3pt hitch (sleeve hitch) you will need to add that also.
Old 01-26-2014, 07:35 PM
Here's what you need ( pictured is my 125 which is a NF , your 149 is a WF )
click all pics for larger views
The tiller mount bolts directly to the rear cover. ( make sure you use slightly longer bolts ) The rear lift will raise and lower the tiller. Since this 125 is manual lift, an IH helper spring is installed. Not installed is the long belt that runs from the front to the rear to power the gearbox.
Here's how the tiller attaches and you can see the short belt since I do not have a cover for it.
Before I started fabricating parts for the tillers, I just dished out a wingnut for the depth adjustment.
As you can see, they do a great job.
Old 01-26-2014, 08:47 PM
Tillers are great on CC's. Bolt on easy-peasy and work great.
Old 01-26-2014, 09:59 PM
Welcome to OCC!
Old 01-27-2014, 09:09 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
If your looking for one that needs fixed, trying to save a few bucks on buying a tiller. Dont do it. You spend 3 times in fixing one then just finding a good tiller. I totally rebuilt my #1 tiller , most all parts are discontinued and you'll need to find bearings and pullies that will work.
Doug
Original , 100 , 125 , 582
Old 01-31-2014, 09:27 PM
thanks for all the great pictures. found one about a hundred miles west of me for $250 i will be checking it out tomorrow.
Old 02-01-2014, 06:39 AM
Good luck!
