Old 01-29-2014, 06:52 PM
pcharles pcharles is offline
Default 1650 power angle plow
Is there any way I can build the brackets and buy a cylinder to fit on a non power angle plow to convert it? If any one has the dimensions for any of this, it would be helpful.
Thank you
x2 1650 dual hydraulics x2 1000's 129 108x2 106x2 104 124x2 123x2 70 72 682x2 147 149 12x2 1200 original 1641 105
Old 01-29-2014, 08:24 PM
Do you have the optional hydraulic outlets on your 1650?
Old 01-29-2014, 10:19 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
I have a set of brackets for one cylinder I not sure my is buried in the barn so I can't get the dimensions right now but if you want the brackets pm me and we can make some kind of deal
Old 01-29-2014, 10:34 PM
yes I have had two 1650s with dual sticks one I parted and the other one I am fixing up I was probably just going to try to make it as close to original as possible but I was going to use a different cylinder
Old 01-30-2014, 07:01 AM
IHinIN IHinIN is offline
This is the power angle setup I built for my blade. The cylinder is 1.5" bore by 7" stroke.
