I am planning a tractor build/mod with either 27" or 30" tall rear tires. Starting with a 128, I will use a 14hp engine with a Kevlar clutch and possibly a stiffer spring or just compress the spring a little. I am thinking that given the gear ratio change due to the tall tires, that in some situations I would be wishing I had a lower gear. One instance especially would be backing a trailer load of firewood. I can think of two options to remedy this, either a creeper gear or a 10% under-drive. The creeper gear would be in high range 99% of the time, very little use in low range. Would the creeper gear unit itself (used in high range 99% of the time) be strong enough to do heavy chores such as pulling a trailer load of firewood or pulling a grader blade? I have read that it is not recommended to use a creeper gear on a plow tractor, but does that mean not to use it in low range, or just not to use a creeper gear equipped tractor to plow at all even in high range. I guess what I am asking is,is the creeper gear a weak link even in high range? So would I be better of with a creeper gear or a 10% under-drive?
Cub Cadet 100 "Super" (red) show tractor Cub Cadet 100 show tractor. Cub Cadet 100 worker Cub Cadet 106 refurbished/modified (red/white) Cub Cadet 128 "refurbished" Cub Cadet 1450 my dedicated mowing tractor Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper. 100 w/pan seat and 3 point hitch |
![]() Quote:
882 diesel, x3 ih 582, 73 124, x2 82 seriers pullers, 1686 16hp puller |
Why not use a set of finals off a low boy? That would slow it back down.
Thanks,guys.Good ideas. I am thinking the Lo-boy finals would be too low.I think I read somewhere they are something like 12:1 reduction.
![]() Quote:
