I just got done spending some sweet seat time on my 149 plowing snow and while I was doing it I thought of a few questions. I was plowing for about an hour and a half having a great time but I was wondering, is all the constant forward and reverse while plowing bad for the trans? I have read here that they are built very tough but has anyone ever ran into trouble? The Hy-tran and filter are new and fresh. Also, has anyone had trouble with hurting the engine for running them that long? I don't mow with it so I am curious. I ran it at about 3/4 throttle. new oil in the engine also. Thanks, Mark
1973 Model 149 42" Snow Blade John Deere X360 John Deere 10 cu Poly cart Squire Applegate 5HP recoil start ![]()
Sorry Guys, It is a 149 Hydrostatic. Im not sure if some had gear drives or if that makes a difference with durability. The engine and Trans are both original and not rebuilt. Thanks again, Mark
Ive been on my 149 for the past 3hrs pushing snow. I really dont think you can hurt it with proper maintenence. Id think mowing tall grass for an hour would be harder on it.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
Like Doug said, If it's maintained, it's doing what it was made to do. Unless you're beating it to death it'll be fine. Mine keep coming back for more.
Its a tractor, using it won't "tear it up". It's not a cheapo box store mower.
![]() When I run mine in snow, I run them good because I have so much I need to do. Like you, I usually run about 3/4 throttle unless I need more which happens from time to time with a 54" blade. In then end, at least by the end today, I will have had a 4+ hour session in the morning clearing work and another several hours after work doing driveways. Just keep them properly maintained, full of fresh oil, hytran, good fuel/trans filters, and you should be good to go. There's a reason these machines have lasted 30 and 40+ years and they keep on ticking
-Ryan
Won't hurt it at all. These tractors were built to work.
Cub Cadet used to have some cubs and drivers that would travel around putting on sort of a circus showcasing the ability of the "NEW" hydro trans and the toughness of the cubs.
Here is a link with some pics http://www.onlycubcadets.net/forum/s...ad.php?t=29383
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
I see more of the older Cub Cadets still being used that I see of ANY Other brand, new models or older units.
My Cub Cadet is a 1976 model 800. This winter, I am doing more maintenance than I have done before, I have pulled the spindles out of the 38A deck to clean and relube them and sharpen blades. A LOT of grease had become dry and chunky inside the spindle cup assemblies, making for rough operation. I'll find out in a couple of months, when I put it all back together.
Only thing better than having a Cub Cadet is USING one
