Old 02-09-2014, 09:39 PM
jonjunk's Avatar
jonjunk jonjunk is offline
Default Briggs and Stratton tank
Hey guys I have a new generator, it's a 1970s mcculloch 1500 watt, it has the 3hp Briggs and Stratton. One problem I have is that it has the tank mounted to the carburetor, obviously that is a problem because the generator only runs for about an hour one that tank, anybody know how I could make it accept a fuel line to an external fuel tank? I'm thinking the pickup tube could have a fuel line clamped to the bottom of it but I don't know if it will work and I don't have another engine to try it on. Any Insight?
122 PTO, lift, deck, weights, and chains clist pick
123 headlights no motor came with the 122
Stx38 free acquisition but its the wrong color works great though
Free craftsman gt 17hp Briggs Intek hydro
Old 02-09-2014, 09:47 PM
There really isn't much you can do with that type of set-up.....
Set a tank next to it and sub-feed the tank on the motor.......
Old 02-09-2014, 09:56 PM
jonjunk's Avatar
My other option was to find a 3hp with the updraft carb but they are hard to find and It would suck setting up the gov.
Old 02-10-2014, 08:02 AM
jimbob200521's Avatar
you could always get a5 gallon gas can or whatever size take you want and just put an electric in line fuel pump on it.
-Ryan
Old 02-10-2014, 10:46 AM
He doesn't have any way to tie a line into the carb....... It's submerged in the tank. It is a fuel tank mounted carb. No fuel line, no bowl.
Old 02-10-2014, 05:34 PM
jonjunk's Avatar
If I could tie in a gas line I would of hooked up an impulse fuel pump to run to a large tank, I plan to convert another Briggs 3hp to a float carb for a mini bike, but a generator needs the gov hooked up and working right., maybe I'll tinker with the other one first see if I can make something work
Old 02-10-2014, 05:50 PM
jonjunk's Avatar
It should work If I cut the wide bottom off of the pickup tube with the screen, then attach a fuel line to it, leave the gas tank on so that diaphragm still functions, run the fuel line out the gas cap to whatever. But I would have to see if the diaphragm has enough power to lift fuel from below, because if I put the tank above the fuel would keepflowing and flood the carb.
Old 02-10-2014, 07:32 PM
I really doubt it. They barely had enough to suck it up out of the tank. If you are planning on leaving this thing run for a long time, you would be better off either, finding a different gen-set, or using a different carb altogether.
Old 02-10-2014, 07:45 PM
With no oil shutdown feature on it I would find another with one one it.Those little motors were not made to run for long periods without checking the oil.
just my 3¢
Up to 534 and counting...
Old 02-10-2014, 07:50 PM
just my 3¢
That's a good point too........
