Old 02-12-2014, 11:07 AM
flkeysdude flkeysdude is offline
Default Can a 1996 2150 AGS be adapted to plow snow ?
Hi Guys...newbie here...I'm stumbling around so don't beat me up if I'm in the wrong thread...??? ;o)
I have a 1996 2150 AGS and am looking to see if I can adapt a plow to it. I have a attachment guide from 7/94 (2 yrs. before the date of my machine) that makes no reference to the 2150. Otherwise, I can't seem to find a p/n that will identify a plow setup for my machine. Does this machine have enough "ommph" to do what I want. Anyone have any input or experience plowing with this machine or any other good advice out there...??? Also, anyone know what does "AGS" stand for ?
Thanks in advance...!
Old 02-12-2014, 12:23 PM
A snow blade was offered for your tractor.
It is a model 302
http://www.partstree.com/parts/?lc=Cub+Cadet&mn=302
That said if you have a relatively flat drive and you go easy you could probably get away using the 2150. The AGS trans is the weak link. AGS or Auto Gear System is a 6 speed with a forward and a reverse set of wet clutch packs. People get in trouble with them by mistaking them for Hydros. The proper way to operate the AGS is to pick the speed with the gear selector and then hold the pedal all the way down in forward or reverse, do not slip it or you will burn up the disks in the clutch just like riding the clutch in a car.
Old 02-12-2014, 04:14 PM
Thanks Sam, for the prompt response...although I have only a small (rather flat) driveway, I was afraid that the 2150 machine might be too light for the job. I also just purchased a 1650 and haven't yet found a blade for that one so I was weighing my options. I think I'll stay away from the blade for the 2150 and go with a real machine to move snow. It's approaching the end of the season so I expect blades for the 1650 might become a little more available as guys who have been holding onto them will be looking to "off" them once the weather breaks...
Thanks again for the good advice...! )
Old 02-12-2014, 04:25 PM
The 1650 would be a much better choice. Glad to have on board at OCC
