Old 02-13-2014, 09:33 PM
gt383mag's Avatar
gt383mag gt383mag is offline
Default Rear PTO - whats it worth?
does this look complete it needs minor repairs what is a fair price looks like the person who removed it had to drill out a roll pin
Old 02-13-2014, 11:03 PM
Every now and again, a buyer gets lucky and finds one cheap...... but typical sale price is $400-$600 used (depending on application, completeness of parts, and condition) and $700 for NOS.
Yours is broken, missing parts and appears to have quite a bit of surface rust. Are the bearings all free?
I don't think it is worth near $400 in the shape it is in.... but, I'm usually a buyer, not a seller.
Old 02-13-2014, 11:20 PM
gt383mag's Avatar
yes everything spins and moves freely
Old 02-13-2014, 11:30 PM
*** See edited post***
Old 02-14-2014, 06:31 AM
I agree with Jonathan.
Old 02-14-2014, 08:04 AM
cjrolke cjrolke is offline
rear PTOs are unique and pricey
I have seen an entire rear sell from 250 to 600
I have an O with Rear Pto bought it cheap ($100)
Old 02-14-2014, 08:19 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Correct me if wrong, but isn't the diff cover plate and the actual output shaft, support casting and bearing assembly common to Cub tractors?
The only thing unique to put it into a CC is the other shaft and engagement brackets and links.
If yes, the "common to Cub" parts can be had cheap.
Old 02-14-2014, 09:59 AM
Yes, you are correct.....
The trans top shaft, and some of the linkage is specific to Cub Cadet. But the rear bearing flange off the F-Cub needs an area machined to accommodate the fill hole on the CC diff cover. Most of the linkage can be made. The real problem is the trans top shaft. It is pretty hard to find item.
Old 02-14-2014, 12:16 PM
cubs-n-bxrs's Avatar
Other than the coolness factor I am not sure what they are good for. Not sure but I beleive they spin backwards requiring the use or a reveser to get them spinning in the correct direction to use PTO operated implements.
Old 02-14-2014, 12:27 PM
i have a belt pulley and 90 degree adapter for mine to run something belt driven
