Old 02-15-2014, 07:50 AM
hdsdcouple's Avatar
Default Rear end gears
Ok so there is no gear swapping in the transmission to make the tractor go faster backwards.
So can gears be changed in the rear ends to make the tractor go faster?
seems there has to be some way of altering gear ratios. I just have not been in these long enough to know how. Yet
or is the only way higher RPM.
Maybe just need to find a 10K RPM motor a shove in one to see what happens.
Old 02-15-2014, 07:53 AM
cubs-n-bxrs's Avatar
Try Midwest Super Cub they offer different gear sets for pulling. Maybe they can help you out. Why do you need more top speed out of the tractor? They move along pretty good in top gear as it is.
Old 02-15-2014, 08:01 AM
Mcamp Mcamp is offline
you can install a one tooth faster input gear in the transmission,it would increase speed in all gears.
Old 02-15-2014, 10:03 AM
mickb72 mickb72 is offline
Or an overdrive.(reduction gear set) It will speed up all gears in trans. Depending on which set, 2,3,4,5 teeth. 10% to 38% overdrive. Mike
Old 02-15-2014, 10:20 AM
hdsdcouple's Avatar
[QUOTE= Why do you need more top speed out of the tractor? They move along pretty good in top gear as it is.[/QUOTE]
Oh I have one I want to make faster, it doesn't have any other use than pull a wagon. so I want to make a speed machine. would like to built a really fast one some day to drive around town since we can drive atv and off road machines on the road here in this state.
45 mile an hour cub cadet tractor I would ride it work, lol
Old 02-16-2014, 08:04 AM
Default cub
Hahahaha! Your gonna need training wheels and wheele bars. Mike
Old 02-16-2014, 08:11 AM
I guess if I was you I would find a peerless rearend that came out of a Cub quite line machine and use that. Then you have the option of swapping pulleys around to get the speed you want. You will still have Cub parts in it.
Old 02-16-2014, 01:21 PM
I am not positive about CC's, but in a manual auto trans the Reverse is accomplished by a idler gear sliding into place to create a change in direction between a cluster shaft gear and the gear on outside of the syncro/ gear brake hub sleeve .which makes it a large gear thus it turns slower but gives more torque
it has to be similar design to get a reverse direction
to change the R gears would take a major design change in 2-3 gears
this slower, more torque gear is useful to extricate a half stuck tractor many times
Old 02-16-2014, 02:08 PM
At 45 mph, I believe that you would have a hard time keeping a Cub Cade between the ditches on an interstate highway... 45 mph on an average 2 lane highway/country road/city street, too scary for me.
Old 02-16-2014, 02:46 PM
hdsdcouple's Avatar
lol I can see it now
Headlines:
South Dakota man dies in rollover accident when his IH Cub Cadet left the highway at speeds exceeding 50 mph. Police are still unsure how the tractor was able to reach speed in excess of 50 MPH but were heard saying that sure would make mowing the yard get done faster.
