Old 02-09-2010, 05:07 PM
Chris W Chris W is offline
Default Snow Blowers
I have a 1984 1512 (782) tractor that I would like to get a snow blower for. I have found two diffrent sellers that have a 190-451 two stage blower.Problem is one sayz it will work ,one sayz it won't. Question is will the 451 work and if not what will work
Old 02-09-2010, 07:48 PM
For the 1512, you can fit:
Snowthrowers
*QA42B
*H48 (Haban)
Snowblowers
190-364
190-450
Anything else, you will have to make modifications.
Old 02-10-2010, 07:27 AM
What is the diffrence between a snow blower & thrower. Any idea what changes are needed to make the 451 work? I am told it will fit right on but why won't it work?
Old 02-10-2010, 07:48 AM
The difference between a snowthrower and a snowblower is. the snowblower has a FAN that blows the snow out the chute. The snowthrower simply uses the spin of the auger to dispense the snow.
I do NOT know the difference between the 450 and 451 snowblower other than the 451 would be a newer implement for newer Cubs,
Old 02-10-2010, 07:58 AM
The 451 has a different gear ratio because the newer tractors it was meant for had a larger diameter PTO clutch, so you'll either need to change the gears in it or put a smaller pulley on the input shaft.
Old 02-10-2010, 08:22 AM
Mak90's Avatar
Mak90 Mak90 is offline
is there a list or manual that would tell you what would fit a certain tractor? or like an interchange? i have seen alot of items listed, and all ask different questions wide frame etc etc
i am new to working on and playing with cubs so any help would be nice
Old 02-10-2010, 12:02 PM
190-450 & 190-451 Snowblowers......
