Old 02-09-2010, 10:44 PM
Masmith Masmith is offline
Default Blade problems.
I have two 149's and both set up with blades. I don't have lift rods for either and have been using chain. One works great and the other disconneted from the QA several times. Is there any adjustment in the locking rod on the front of the tractor and do they wear out? Any thoughts would be great. I thought it might be possible the chain allows the blade to raise up and hit the QA rod.
Old 02-09-2010, 11:08 PM
wshytle wshytle is offline
It sounds like you need a couple of latch springs. If the blade pushes up on the bar it shouldn't unlatch because the bar pulls down to release. You can tie the bar up with bailing wire or something for a temp fix but I'd just get the springs. The sponsors have them.
Old 02-09-2010, 11:28 PM
Sometimes you just need someone to show you the obvious. The whole time I was having trouble with it, I was thinking the locking rod needed to stay in the down position, and I should know better. Pulling it up and using wire or a wiretie would do the job. Thanks.
Old 02-10-2010, 08:27 AM
This may help......
