Old 02-28-2014, 12:30 PM
IsaacSchuler's Avatar
IsaacSchuler IsaacSchuler is offline
Question K161 Question
I have 2 questions. 1 I pulled me engine apart and there was Metal fillings in the oil and on the crankshaft but nothings broken so wheres it from. 2 when i pulled it apart there is no timing marks on the cam shaft gear and the crankshaft gear. So how do i line it up to get the timing right when i put it together?
Heres a video of my problem.
https://www.youtube.com/watch?v=nbA5u3edgUQ
play like you're in first work like you're in second
My Facebook Group
Old 02-28-2014, 03:05 PM
Here is a copy of the service manual available in our tech section....... K Series Service Manual
OR
I know a guy....... Rebuilt engines.
Old 03-01-2014, 07:34 AM
randallc randallc is offline
Timing marks are there. a little o stamped on the cam and a - on the crank. Check the bearings or shims, the end play is there for some reason. Go through the service manual and replace the seals while they are handy. Good luck.
