Old 03-05-2014, 02:59 PM
dboyles dboyles is offline
Default Cub 100 Carburetor
My 100 is acting up and I suspect it may be the carburetor. I've already had it running this year and turned about 75% of the garden last week. While it was running though, I had to leave the choke on the entire time otherwise it would die.
The last time I used it, it kept running worse and worse until it wouldn't run at all and hasn't cranked since.
I cleaned the points and put in a new spark plug and neither seemed to help. After reading some on this forum, I checked the throttle shaft and there seems to be some play in it.
Question: Should I buy a kit(s) and rebuild this carburetor or buy one of the aftermarket carbs online?
If I rebuild this one, where is the best place to source parts, and what exactly will I need?
Is there anything else I might need to look at on the tractor as well?
Here is a picture of the top of the carburetor. The linkage looks a little different than some of the other pictures I've seen. I also noticed that the linkage is broken at the throttle shaft and just seems to be sitting there, not really fastened.
Let me know what you think. I'm not the sharpest knife in the drawer, so please type slow.
Don
Old 03-05-2014, 03:30 PM
Sounds like it is just plugged up. Take it apart and clean it. Buy the kit, put it in. That isn't really rebuilding it, but it should help. If you can lift that ball and socket joint up off the linkage, then it is broke. New ones are available from cub cadet.
Old 03-05-2014, 06:45 PM
The ball and socket is not the part that's broken. It's the part that sits on the throttle shaft. Would that be a part of a throttle shaft kit?
Old 03-05-2014, 08:58 PM
Merk Merk is offline
The early 100s had a Carter carb on them. The top part and throttle shaft are different. You can use a Kohler carb rebuild kit. I had 2 carbs that style and had to modify the throttle shaft to make it work. I had to mill a flat on the newer throttle shaft to make it work.
If you do not have access to a mill I would find a newer #26 carb.
Project Uncle Dick
Cub Cadet 70
Old 03-05-2014, 09:42 PM
It kinda sounds like the fuel supply is clogged somewhere.
If you take the line off at the carb and there is good flow then it is most likely clogged from the seat back to the elbow that screws into the side of the carb. You'll need to take the carb off and clean the fuel passage out. Best to rebuild it, but you may get by with just cleaning it out well.
If you do not rebuild the carb, take the high speed screw out (screw it in all the way (finger tighten only) counting the turns, so you can put it back in close to where it was) and clean the tiny holes in it out, the needle is actually a tube so clean out the tube part too.
This would also be a good time to clean out the tank and replace the filter or clean the bowl.
If the part (throttle lever 385 496 R1) that slides down over the throttle shaft is actually broken, I'm not sure what to tell you. I have never had to replace a throttle shaft and have never looked for a throttle lever, it may now be made onto the throttle shaft. Hopefully someone else will know.
If that part (throttle lever) is not broken then you can tighten it up with the pinch screw on the side.
You can order a kit (it will have everything you need) from one of our fine sponsors at the top of the page, or get it from your local NAPA dealer.
Be sure your timing is set correctly, check the tech section for the ideal way to set the timing.
Good luck.
Old 03-06-2014, 08:36 PM
I took the carburetor apart tonight and as you all said, it was very crusty on the inside. There was a lot of trash in there.
One of these screws looks a little curious.
Is that normal?
And here is the broken throttle linkage.
The carburetor is a Carter Model N. I'm looking for kits for it now.
The throttle shaft is a little loose, so I will probably go ahead and install a bushing, too.
Don
Old 03-06-2014, 10:22 PM
I gotta agree with Merk now, Get yourself a newer 26 then sell that one for parts on ebay and get at least half your money back.
Old 03-07-2014, 05:45 AM
This tractor will be always be a worker. I'm not concerned about keeping it original. So, in your opinion, would an aftermarket carb be an option?
Like this?
http://www.ebay.com/itm/Kohler-K241-...item35cf1ef1c8
Or this?
http://www.ebay.com/itm/Kohler-K241-...item2ecf23235d
Or would a used one be better like this?
http://www.ebay.com/itm/Kohler-10-12...item35d2bfac2a
None of the throttle linkages look like mine, but they look like they might work.
Old 03-07-2014, 06:57 AM
dbuck dbuck is offline
Smile
Like this?
Or this?
If it were me, I go for the 1st one @54$'s. The used one is 50$'s plus the cost of the kit. There is more info, go to Cub Cadet engines, Kohler section, look for aftermarket carbs, there are two different posts.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 03-08-2014, 05:46 AM
I ordered the carb and a gasket. The choke linkage appears to be on backwards as was mentioned in another post, but I'll figure something out when it gets here.
