Old 03-24-2014, 04:41 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
Default The 1811 project
I finally had time with the threats from my son to start working on his 1811. Here are a few pics of the work we got done the past two weekends.
Front tin removed and engine removal
Look at the foam the PO sealed the engine tin to the fire wall with
My son pressure washing the frame and now wanting me to sand blast and paint it.
The engine is on the bench waiting for teardown. Looks like the deck is going to need a complete overhaul,more on that later.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 03-24-2014, 05:02 PM
Thanks for the update!
Old 03-24-2014, 05:24 PM
jimbob200521's Avatar
Looks good! The 1811 is I think my favorite worker Cub so far out of the dozen or so I've had. Great machine.
That foam is supposed to be there too, btw
-Ryan
Old 03-24-2014, 08:02 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Think you might spring for power steering while its in the operating room?
1- 1200 in pieces
1- 1864 in pieces
Old 03-25-2014, 12:37 AM
inspectorudy's Avatar
I have an 1811 and I can tell you that adding PS will be the best thing that you can do to the old girl! It made mine into a tractor that I love to drive from a utility vehicle that I had to use. It is much easier to do it while everything is apart than to do it later.
1811 Hydro
Old 03-25-2014, 09:35 AM
Darrell Darrell is offline
And there is supposed to be a piece of foam between the engine and the motor mount plate. They are there to help blow cool air thru the engine and out the front.
Old 03-25-2014, 09:59 AM
red56turbo's Avatar
Nice father/son project. The paint doesn't look too bad from here. Of course it could be the wetness of the water.........
Josh
Diesel Cub Cadets...........
Old 03-25-2014, 10:32 AM
The 1811 is still my favorite tractor. I have restored about ten JD's and many different models but there is something about the 1811 that makes it my favorite to use. I think it might be the position of the seat and the drivability of it. Of course the PS helps a lot too. You will enjoy it and be proud of your work when you finish.
1811 Hydro
Old 03-25-2014, 11:24 AM
Good luck on the project! Looking forward to your updates.
Old 03-25-2014, 01:25 PM
RR1862CC's Avatar
Thanks for the replies! I would love to add power steering and dual hydraulics but the money is not in the budget until my wife finishes school next year The foam looks like it had been cut out of a block instead of a factory piece but I wondered if they came with the foam.
Here are a couple of pics of the deck. It is solid but I need to weld up some cracks around the rear deck hangers and smooth an old weld made by the PO. All three spindles are frozen and the blades are shot.
Here is the bottom. I do not know if you can see but half the baffles are ripped out. Hopefully I can make a new one at work and weld it in.
Allis Chalmers 416
Brinly 10"plow
