Old 03-24-2014, 07:35 PM
texretvet texretvet is offline
Default Fuel usage 1450 v. 2182
Since my 2182 is down right now, I mowed with the 1450. I am amazed at the difference in the fuel consumption between the two.
I mowed about 2.5 acres with right at 1 gallon of gas. That same amount would have taken at least 2 gallons with the 2182.
Might have to make it a regular thing!
CC 2182 w/ Cat. 0 3pt. lift 54"GT deck
IH CC 1450 w/ CC #2 tiller and 44" deck
Old 03-24-2014, 08:22 PM
Pauld Pauld is offline
Wish I was cutting grass w'ere going to be plowing snow Wednesday
102 ,129 ,149 ,169 ,154, tiller .chipper
wide frames rule
Old 03-25-2014, 08:42 AM
Berwil's Avatar
Berwil Berwil is offline
I had the exact opposite experience with my 1450, it's a fuel hog! Then again I'm comparing it to cutting grass with my O.
Bill
Old 03-25-2014, 08:52 AM
jimbob200521's Avatar
Had similar results this winter, when the thrower was on the 1811 or 682, I'd have to fill up after a couple hour full throttle blowing session. When it was on the 129 I had (with a 14hp Kohler) I'd still have to fill up every couple hour blowing session but then again, you're looking at a 1(ish) gallon tank vs a 4 gallon tank
-Ryan
Old 03-25-2014, 09:30 AM
kostendorf's Avatar
I've heard that all vehicle manufacturers use a formula to figure out what size tank to install so the car or truck could travel close to a 400 mile trip before refueling. I wonder if that is true for other machines in hours such as tractors and mowers.
Old 03-25-2014, 09:36 AM
If a hydro 1450 seems fuel stingy, try a gear drive,,
I can plow snow for an hour with a quart of gas.
The hydro is wasting at least 20% of the HP, and gasoline.
Old 03-25-2014, 11:20 AM
My 100 was a lot better on gas, than my 782 and 1872. Course the 782 and 1872 have twins in them versus the single in the 100.
Old 03-25-2014, 12:15 PM
Allen has the right idea guys.....
If your feeding fuel to a 40 cubic inch motor, and a 31 cubic inch motor, which one do you think will burn more? More cubes = more fuel.
Old 03-25-2014, 12:31 PM
Shaner Shaner is offline
The Kawasaki I have in my John Deere gator is the most fuel efficient engine I have. Fill it, forget it. Compared the the kt twin or magnum twins I have are fuel pigs.
Old 03-25-2014, 12:56 PM
I really doubt the engine in your gator works as hard as the engines in the tractors though.....
While were on the subject of fuel consumption......
A bigger engine when compared under loads to a smaller, may in fact burn less fuel than a smaller engine. Because of the size difference, it doesn't have to work as hard to complete the same task. So, load comparison is ultimately a factor.
