Old 03-28-2014, 10:59 AM
alsparl alsparl is offline
Default Magnetic Drain Plugs
I am hoping to make a few minor adjustments / upgrades for my 782. One of those, due to the age of the machine, is I would like to get a magnetic drain plug for both the engine as well as the transmission. Some may consider this overkill, but when you don't have the money to replace it or have a large repair bill of some sort, I consider this the same as preventative maintenance.
I know this topic has been discussed somewhere in this forum, but for the life of me, I cannot locate it. And to think I thought I even saved those threads and still can't find them...ugh.
With that being said, if anyone would be willing to help me with the size of both and a purchase location, I would greatly appreciate it. Thank you for your time and consideration.
Aaron
Aaron
'83 782 #723927
****original KT series 1 engine
****added dual hydraulics from older, donor 782
'04 SRC621
'95 Magnum (M18S) spare engine
****spec 24646
****s/n 2507913316
Old 03-28-2014, 11:07 AM
Every time I build a hydraulic machine (woodsplitter etc,,,, ) I add a large magnet to the inside of the hydraulic tank.
Cheap insurance!
Old 03-28-2014, 11:12 AM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
You can take the old drain plug with you to a real auto parts store and they will fix you up with a magnetic drain plug. Most of the better counterpersons will know the thread when they see it. If not, they have thread size checkers. You will be in and out in under 10 minutes.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 03-28-2014, 11:14 AM
There is even a YouTube video showing the results of adding a magnet!
https://www.youtube.com/watch?v=vjRmrYqKmPM
Old 03-28-2014, 11:48 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Yea but you have to tell the counterperson all the vehicle info and if it has red or yellow turn signals to figure out the drain plug.
Old 03-28-2014, 11:49 AM
Just about the only thing that fails in the engine is a rod. It's aluminum.......
Old 03-28-2014, 12:08 PM
gsomersjr's Avatar
That's why I said go to a REAL parts store.
Old 03-28-2014, 01:53 PM
You have never seen the bore of an engine after I have used it!
Old 03-28-2014, 02:28 PM
http://www.drainplugmagnets.com/
Old 03-28-2014, 02:41 PM
$35 is kinda pricey, they sure brag about their magnet power though!!
