Old 03-30-2014, 12:55 PM
Ryder Ryder is offline
Default My Cub Cadet is up and running again!
Well my 1974 Cub Cadet 86 sat for awhile and i finally have got her back to running and mowing. I did a little carb clean and replaced the rear oil seal and now she is running perfect!
Quick question, my front rims are rusty, what is the best way to remove the rust but keep the paint intact? If there isn't a way to do so, what is the best way to remove the rust and paint the rims?
Old 03-30-2014, 04:11 PM
86 looks great
As per your question. There isn't any paint to keep if it's rusty, best thing would be to remove the tires and have the rims sand blasted. I at one time had no way of removing the tires so I just blasted the wheels and taped off the tires and painted.
Blasting isn't going to hurt the tires, but your only going to get at what is exposed. If it were me, do it right the first time.
Old 03-30-2014, 07:31 PM
Great to hear that the 86 is back in business!
Old 03-30-2014, 07:47 PM
Nice looking 86.
Old 03-30-2014, 08:48 PM
Great news!
Old 03-30-2014, 09:26 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
before paying to have the tires demounted and rims blasted and repainted, take a wire brush to the rims.
You might find there are rust pits all over that will be enlarged upon sandblasting.
If you do not want the dimpled surface, you might want to entertain new rims.
Old 03-31-2014, 02:43 PM
amy3588's Avatar
amy3588 amy3588 is offline
Use a 4" angle grinder with a wire brush attachment to clean the rust off then wipe them clean and check for pits from the rust....my guess is you could at this point prime them with Rust-oleum then a good paint and you should be ok...You can full the pits if they are too bad to save on buying new rims....
Nothing runs like a Deere with a Cub on its tail !
