I'm not sure if this is the correct place to post this, if not could someone move it to the correct area?
I'm wondering if a 3 point hitch from a 107 will fit a 149? Thanks for any input! |
No it will not.about the only part that will is the lower u shaped bracket that attaches to the trans.
Welcome to OCC! Glad to have you!
Welcome to OCC!
Thanks I have a 107 with a bad trans, and other problems. I found a 149 with a mower deck, and front plow for 600 bucks. I was thinking of buying it, but I need a 3 point hitch for my implements. What's available for the 149 model? Only the U shaped bracket on the trans? I want to use it for plowing.
And thanks for the welcomes. |
No, the upper part is out there. But the 149 is a wide frame, and the 107 is a narrow frame. They use different "rockshafts" (for lack of what else to call it). The 149 also uses a different bar. Put an ad in the wanted section. Or try the sponsors at the top.
Why not fix the 107? The hydro trans VERY seldom fails. Usually the relief valves with are easy to change and can be bought rebuilt for less than $100. Or, if it truly is bad, a used hydro usually brings $100-$125. Rear end parts about the same. WAY cheaper than buying another tractor that will probably need some attention. ![]() |
