Old 04-01-2014, 11:34 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Default Dads adapted Sears 3 point
My dad always used Sears/Roper 3 points on all his cub cadets. He built the adapters to make them work with manual lift or hydraulic lifts. They all work great. They are much easier to adjust and work with than the brinly setup. You can make the equipment perform just like a large ag tractor.
Pictured is one he did back in the early 80's when this 782 was new.
The planter started life behind a David Bradley walking tractor. It was made by Cole for Sears. Dad converted it to 3 point and added the fertilizer distributor back in the late 60's to use with a Cadet 100 that he had back then. The sweeps and tool bar are from a Roper cultivator.
I Just used it today to plant my garden. Just put in the seed and fertilzer and take off. It lays the row out, drops the fertilizer and seed, and closes the row up all in one pass. Works like a dream just like it has for the past 40 plus years. Just thought to take a picture and share it. Figured others may be interested.
Jay
Proud owner of the following:
Old 04-02-2014, 12:45 AM
Very nice adaptive maneuvers: beerchug:
Old 04-02-2014, 01:24 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Two things. 1st I LOVE that little planter!! 2nd... I like the hitch plate on the front of your rig we have made those for some of our tractors. Makes backin a four wheeled wagon perdy painless
1- 1200 in pieces
1- 1864 in pieces
Old 04-02-2014, 06:18 AM
Looks good!
Old 04-02-2014, 10:55 AM
That's pretty cool!
Old 04-02-2014, 03:49 PM
Steve N Mi Steve N Mi is offline
This comes at a great time as I'm contemplating a 3pt. for my 1872 so I might use several of my Sears/Roper attachments on it. In the normal slant position a Sears 3pt. snaps over-center so the weight of whatever is being lifted is then concentrated on the 3pt. linkage. The operator no longer has to strain to hold the load. Mounted vertically as you have it, perhaps all the load is on the hydraulic system??? I can't make out in the pictures if the factory Cub Cadet rockshaft is connected to the lift or there is a straight link from the lift cylinder to another connection point on the Sears rotating (rockshaft like) horizontal shaft? Maybe a couple of more photos to clarify this for me. Thanks for your post, Steve
Old 04-02-2014, 05:51 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
I think I see how it works. It looks like the original IH 3 point rod hooks to the top of the sears 3 point.
Old 04-02-2014, 09:05 PM
jaynjeep's Avatar
Default Sears 3 point
Steve,
It does use the factory cadet rocker shaft. He came out of that and built a fork as such with two lift links that he welded to the factory sears cross shaft. in this configuration it does not over center. The ones that he did where he used a manual lift lever like the Sears do overcenter. I will try to get some better pics for you tommorow.
He has quite a few different implements that he uses with this setup. Some of them are just the way Roper/Sears built them and some he has built or modified. At one time 20 years ago he was tending at least 15 different gardens with this setup. People would pay him to come over, turn the ground, lay out the rows, plant, and later cultivate their gardens. Back in the 80's this little tractor with the Sears equipment could make him $25 per hour. He hauled it all around to the different customers on an IH #7 tilt bed trailer. It is pictured in one of my albums.
I'll work on some more pictures.. we have this setup on a 1450 also... it is a little more refined and looks a bit more factory. Both work well.
Thanks
Jay
Jay
Old 04-03-2014, 11:29 AM
Welcome to OCC! Hope to see some pics of your 1872.
Old 04-04-2014, 04:29 PM
Originally Posted by jaynjeep View Post
Steve,
Thanks
Jay
Jay, some neat history in your post. Yes, some more photos could/should/would be helpful, thanks. Steve
