Old 04-05-2014, 09:14 PM
gmbadgley gmbadgley is offline
Default Spindle bearings
Anyone ever try machining a ST 745 spindle & housing out to accept a standard bearing? My son in law loves a challenge so I threw that out to him. Is seems like it should be a fairly easy modification, the hardest part will be getting the balls out to separate the shaft & housing. I figure a die grinder will cut a slot to roll the balls out one at a time.
Once they are apart the shaft should be an easy turn down to fit a bearing on and the inside of the housing turned out to fit a bearing plus a snap ring groove to hold everything together.
With the price of the spindle assembly anywhere from $85 - $180 I think it may be a good alternative if Tom can machine it. Even if I have to spend $20 for each bearing I will be money ahead. The spindles are one step from scrap so I really don't have anything to loose.
It works on paper!!
Greg
"If I can't fix it, I can screw it up so bad no one else can either"
Old 04-05-2014, 11:26 PM
I don't know what a ST-745 is.....
Is it the deck model? It doesn't come up in the parts books......
Old 04-06-2014, 12:36 AM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
An ST-745 appears to be a special bearing assembly used on the 38, 38A, 38C, 42, 44, 44A, 44C, 50, 50A & 50C decks for the spindle bearings. It looks to be a pair of ball bearings packaged into one case. I attached a picture off the web. A neat feature of this assembly is that you grease it from the top and the grease is dispersed into the interior cavity to both bearings.
Given the vast number of bearings out there, there stands a good chance a bearing that fits the OD/ID and overall construction (ball bearing-type) characteristics exists. A collar would need to be sourced to obtain the correct spacing for the bearings, but there again, something probably exists that would fit the application.
I have to do this to my deck before mowing season starts - it's an interesting situation. Do you spend the money up front for the bearings to save time in the end, or save the money up front to spend more time finding/applying a different solution? Either way should yield the same results (in theory).
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 04-06-2014, 01:03 AM
I'd just get an older style hub that uses the tapered cup/cone and never worry about it again.
Old 04-06-2014, 08:22 AM
Around here parts used parts are starting to dry up and many of the people that have some treat them (and price them) like Gold.
One guy wanted $55. for a USED Kohler carb that was painted to give the illusion of rebuilt. And BOTH of my decks (42 & 50) take this style, The 42" spindles are shot, the 50 is not too bad yet.
If I have to I will but new spindles, but this looks like it may work. If so We may be on the way to a new venture!!! I'm sure the money will just roll in by truckload I also have a few used bridges and Ocean view property in South Dakota for sale also!
Greg
Old 04-06-2014, 11:17 AM
RLause's Avatar
RLause RLause is offline
I've had the same thoughts. Cut the old outer race, heat the spindle to remove the hardness, and turn the spindle to accept the new bearings, leaving a land between the new bearings to hold it in place. I'm going to try it when I get time.
Richard
Old 04-06-2014, 11:19 AM
litlmikeyl's Avatar
I snooped around a bit more on the interwebs and found the attached picture on another site. The ST-745 is on the bottom with two other bare spindles pictured. Also found was a service kit sheet for the spindles in the attached picture.
Given the thread size for the top nut probably wouldn't be a goofy size due to it's age (read: its too old for a strange SAE or Metric thread) and seeing that the OD of the shaft itself LOOKS darn close to the major diameter of the threads, a slight modification just might do the trick to the use of other bearings.
I'm curious what you come up with Greg. This discussion is veering me towards what your doing instead of buying the new big bearings or swapping out the housings.
File Type: pdf CC Spindle Service Kit 759-3369, 759-3370, 759-3676.pdf (63.9 KB, 56 views)
Mike - Ramsey, MN
'65 100 - #126432
Old 04-06-2014, 05:04 PM
Tom took one this morning, he said he's going to play with it at work this week and see what happens. I'll let you guys know what happens.
Greg
Old 04-27-2014, 10:00 AM
I talked to Tom yesterday, He did get the first "Prototype" done. He said the shaft is "Super hard" and could only take a .005" cut at a time on the lathe and the lathe had all it could do to get through it. He said it is a little tighter than he would like, but should be fine.
I'm sending the other 2 spindles up with the granddaughter today. I'll see if he can get a few pictures of them before they go together.
Greg
Old 04-27-2014, 10:43 PM
Greg, might see if he will just make a new shaft. He has one to go off of, and it may take less time. Just a thought.
