So I am putting in a new clutch from midwest super cub, and I was going to take the three pin driver off to check the bushing. I removed the four bolts and tried gently prying on it but it will not move. Has anyone had this problem and is there a secret on how to remove it without tearing up the flywheel screen?
Marshall |
sometimes gentle don't work. you have a steel clutch driver and an aluminum cup. you could try some heat on the drive cup , might help
Ive always had luck using a rubber mallet. Just kind of work it back and forth. Some pb blaster helps also
No more cubs. But never fear there will be more ![]() ![]() ![]()
