Old 04-16-2014, 07:25 PM
Tunames Tunames is offline
Default M18 vs. M20 question
I have an 1812 with 900+ hrs. I also have a 2072 with 600 hrs. I just got last fall. The m20 in super runs so smooth compared to the m18 in the 1812. Its ran like that for the last 7 yrs. Is that typical of the 18's and 20's? Would the 18 be in need of a rebuild? or would it be better to repower it? and with what? I've always liked the 1812 but I'm REALLY liking the 2072! Advice and opinions welcome....
Old 04-17-2014, 09:39 AM
I've rebuilt carb (walbro fixed main jet) fuel pump is good,good consistent spark. I haven't pulled the heads to decarbon. I've started running sea-foam in the gas seems to help but still sounds like one cylinder cuts out intermittently sorta. I just thought it was normal for the magnums! Until I got the 2072....
Old 04-17-2014, 10:24 AM
They should both run about the same. The 18 may need a little TLC.
Old 04-17-2014, 01:16 PM
Both engines are identical except for the carbs. Should run exactly the same. Tune the 18 up, clean the fuel system, and while your at it do a compression check. Figure out what's wrong with it and fix it. It's never "normal" for an engine to run rough.
Old 04-17-2014, 03:45 PM
Compression is down 88lbs. Both cylinders....
Old 04-17-2014, 04:04 PM
That's lower than I like to see..... but it's not horrible. Pull the heads. Clean it up, check the valves. May even just have a leaking head gasket.
Old 04-17-2014, 04:11 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Agreed! Don't forget to clean and lube the starter while it's apart
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 04-17-2014, 04:40 PM
jimbob200521's Avatar
I didn't know that! So a guy could get an M20 carb and put it on an M18 and be good to go then?
Didn't mean to thread jack BTW
Edit: According to the Magnum manual, the strokes and compression are different between the two. Oh well haha
-Ryan
Old 04-17-2014, 05:45 PM
Yes, my bad, I know the stroke is different. Same bore, same jugs, same pistons. Compression is different because of the stroke.
Old 04-17-2014, 06:20 PM
snoel's Avatar
snoel snoel is offline
Longer stroke should not have different compression. Unless someone has been "fixing" it. Factory compensates for it in the design.
Steve
