Old 04-16-2014, 09:54 PM
SS5150's Avatar
SS5150 SS5150 is offline
Default 1710 hydro/rear end
Just a question, I have an IH built 782 with the cast iron rear diff and last fall I bought a rough 1710 for the engine.....anyway engine's out and tractor is gone but I still have the rear diff and hydro assy. Is there any reason to hang onto these? I've already swiped the hydro relief valves and I was thinking that the diff is kind of useless to me since I have the IH diff in my tractor. Tractor showed just under 2,000 hrs when I bought it. I also have a parts IH 782 with a complete cast diff and hydro. Thanks.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 04-16-2014, 10:50 PM
Tunames Tunames is offline
If it's the aluminum housing the internals won't interchange. So unless you have a CCC or MTD machine. ....
Old 04-17-2014, 12:03 AM
The aluminum one has better axles and IIRC they will work in a CI rear with a little machine work if you swap all the guts. You probably won't need them but the puller guys will buy them up. Good luck.
Old 04-17-2014, 12:27 AM
Yes they will.
