Old 04-19-2014, 04:24 PM
Tunames Tunames is offline
Default M18 pto
While I have the engine out of the 1812 is there any regular service I should do to the PTO? As far as I know there are no issues with it...just easy to get to now
Thanks
Old 04-19-2014, 06:02 PM
As long as the bearing or bearings are good not much else you can do.
Old 04-19-2014, 06:08 PM
I'd blow the dirt out of it really good, spin the bearings, and make sure none of them feel rough. Check the coil to make sure the epoxy isn't bad. Nothing you can do if it is, but if it is and you know it, if it fails it won't be as big a surprise.
