Old 04-27-2014, 06:55 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
Default Exhaust pipe analysis
Most of you guys probably by now know that I say exhaust pipe diameter and length is critical. playing with a 16 stocker on the dyno today. I cut 3 1/2 inchs off of the pipe and lost 2 ft lbs of torque. so I welded it back on. picked up 2 ft lbs of torque. put a lollipop in the exhaust and started adjusting back pressure and picked up another .5 ft lbs of torque.
Old 04-27-2014, 09:21 PM
counciltucky's Avatar
counciltucky counciltucky is offline
sorry but I am not formilliar with lollipop, and how that works can you explain? Also could you help me with the length of pipe for improved torque
63 original
64 cub 70
65 cub100
67 cub 104
108 puller
127 hydro
129 hydro
149 hydro
Constitutional conservative
Old 04-27-2014, 10:05 PM
fourinchdragslicks fourinchdragslicks is offline
It is basicly a damper, a washer welded on the end of a stud...you turn the stud in the exhaust to block more or less of the pipe area with the washer. With pipe length, you are "tuning" the exhaust for your target operating conditions... rpm under load... if I remember right it you are using the diameter and length of pipe to optimize scavenging effect under your target conditions.
Old 04-28-2014, 07:22 PM
dvogtvpe's Avatar
your pretty much on as far as exhaust tuning goes. I use a 1/4 in eye bolt and weld a washer to it then round it off a bit. its a little sturdier.
I've never played with one on a 4 cycle , they are more popular with 2 cycles. it was worth the time for a .5 of a ft lb of torque. I would have liked to play with it some more but we had close to 20 runs in 4 hours and I was ready to call it quits for the day.
Old 04-28-2014, 08:58 PM
Everything you do on an engine affects power. Ask me how I know. Pic of one of my engines on the Dyno
Old 04-28-2014, 09:15 PM
I'm really surprised that a little back pressure increased torque. Got any ideas why? I've got a theory.....
Old 04-28-2014, 10:33 PM
OffTime's Avatar
OffTime OffTime is offline
I thought that back pressure would only decrease the scavenging effect as well, therefore decreasing torque. I'm interested in that explanation.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 04-29-2014, 10:27 AM
mickb72 mickb72 is offline
Waiting to see what Don has to say about those singles. I know he said 25" earlier. I am building a stock 16 one now and have a pipe i don't like. It's a 3 stage mainly for open rpm motors. It was cheap and delivered. The kid wouldn't call me back, i was gonna change the design, guess I'll be doing some chopping. On my stock 25hp twin puller Jullian at MWSC told me the smaller pipes 11/8" were better. Good for 2 or 3 hp. The two into one pipe. He says those stock twins like the back pressure and they sound great. Mike
Old 04-29-2014, 04:26 PM
Talking about changing pipe diameter to change torque or curve of torque.
Years ago, I used to ride motocross, hare scrambles and enduros. One of the last bikes I rode was a TM 400 Suzuki. 40 hp/220 lbs. No flywheel. The throttle was either on/off, there was no in between. Like a light switch.
The thing had a tuned pipe on it called an expansion chamber. Tuned for wide open throttle.
One day, I hopped across a very large log and didn't quite make it. I bottomed the bike out of the log and the exhaust pipe got mashed about half shut.
The immediate effect was, all of a sudden, the bike became manageable at slower speeds and would now lug along where before, like it said, the throttle was like a light switch. I never fixed the mashed pipe.
Old 04-29-2014, 06:09 PM
nikster's Avatar
nikster nikster is offline
This topic is way beyond my comprehension of fabricating
Doo-Hickeys?
NIK,
I guess if one is into pulling/racing a small 12hp., it would be usefull?
