Old 04-28-2014, 03:05 PM
Baystalker Baystalker is offline
Default Grass bagger
Question I have a LT1050 and my buddy has a OCC-190-678 bagger for a LT1046 is there any way to adapt it to my mower.
Thanks
Old 04-28-2014, 10:46 PM
Moark Willy Moark Willy is offline
Exclamation
The frames are identical on these machines, so the bags will attach without a problem. But there is a difference in the chute. I would check to make sure it will attach to the deck first, by checking the discharge measurements of both.
It is likely you will have to extend the chute in some fashion. If you can get it for a reasonable price I would think you should go for it. You will need hi-lift blades however for it to work properly.
Old 04-29-2014, 11:28 AM
Thanks MW I'll check it out.
