Old 04-29-2014, 01:49 PM
pete240 pete240 is offline
Default 782 Repower with CH25?
Will a CH25 fit in a 782? I found one on CL http://hartford.craigslist.org/grd/4423738961.html
If I remove the grass screen, will there be a place for a drive shaft to bolt up, or do i need to find a different engine?
Old 04-29-2014, 02:18 PM
Yes. You will just either need a different screen, or cut the center out of that one.
Old 04-30-2014, 10:55 AM
Would a driveshaft and rag joints from a magnum engine work? Do i need to figure out which way the engine spins or are they all the same?
Old 04-30-2014, 11:05 AM
Should and yes, they all spin the same way. Driveshaft length is going to change though. You would be better off going to a CV shaft off a newer tractor.
Old 04-30-2014, 11:46 AM
Thanks for the info!
Old 05-01-2014, 10:58 AM
Lets say i came across a 2185 with a CH18, I think that would be a better option, No? I would be able to use the driveshaft and engine mounting plate and PTO and not have to hunt parts down or fabricate much, correct. The other option is I have a M18 that needs machining and rebuilding and a PTO.
Old 05-01-2014, 11:08 AM
Read this thread to give you an idea what you'll need.
http://www.onlycubcadets.net/forum/s...ad.php?t=31345
If you get a 2185 you can use the drive shaft but it needs to be shortened. Easy way is to get the drive shaft, motor plate and muffler from an 1864 then you'll still need a pump adapter.
Old 05-01-2014, 11:11 AM
Odd... My book doesn't show a 2185, but they did make one..
No you will still have to mod the driveline no matter what. There is no "direct fit" driveline on the "V" motors. They all have to be changed at least some to work in a 782. I'd go with the bigger engine because well..... its bigger. More HP is always better!
The M18 is the only one that will bolt in and work with the existing driveline. But, as I seem to be saying on here a lot, better check into prices of rebuilding the Mag..... they are PRICEY!!!
Old 05-01-2014, 11:20 AM
[QUOTE=J-Mech;258745]Odd... My book doesn't show a 2185, but they did make one..
QUOTE]
http://www.tractordata.com/lawn-trac...adet-2185.html
Old 05-01-2014, 11:30 AM
Where you say 1864, do you mean 2185? would the motor plate and muffler from the 2185 work?
