Old 04-30-2014, 02:42 AM
Tunames Tunames is offline
Default 1812 PTO question?
PTO works fine. Bearing is good the coil has some cracks in the sealer you can see the windings in one tiny spot. Can I clean this up and reseal it? I've heard job weld and epoxie. This thing is filthy can I clean it in the parts washer? Soapy water? What do you recommend?...
Thanks
Old 04-30-2014, 07:11 AM
You can clean it up a number of ways. Personally, I would use lighter fluid. Anyway, once clean, make sure the coil is DRY. Then you can seal the crack(s) with something like JB Weld, Epoxy, or High Temp RTV.
Old 04-30-2014, 12:18 PM
Ok thanks if that's the case I'll use denatured alcohol.
