Old 05-05-2014, 03:26 AM
cubby102's Avatar
cubby102 cubby102 is offline
Default Just wondering - decks
Was just wondering what yalls favorite mower decks to use. Personally I have had 38 42 48 44a and 50a and my favorite would have to be the 48 for cleanest cut. What are yalls favorite
Old 05-05-2014, 07:23 AM
60" Haban's are my go to weapon.
Old 05-05-2014, 08:43 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I am partial to the 42"
1. because I can load the tractor with mower into the bed of a fullsize pickup.
2. Does not scalp the lawn as much as the 48"
Old 05-05-2014, 09:19 AM
PaulS's Avatar
PaulS PaulS is offline
I like and use a 54 in deck under my 2084. I would use a bigger one but the 54 just fits through my shed doors. I used a 42 in on a 102 for many years but always seemed to have problems with leveling the deck and or getting all three blades to be even.
Old 05-05-2014, 09:55 AM
I've used a 48" under a 125/147 and a 50" under a 782. The 48" are the best IMO for cut/look.
Old 05-05-2014, 11:11 AM
Leadslingingdaddy's Avatar
HABAN 60!! Beast...
Old 05-05-2014, 11:16 AM
red56turbo's Avatar
My vote would be for a 44" deck. They are more manueverable and fit in tighter spots than a 50". If you have the deck set level, a speed up pulley, and gator blades, these decks mow great! (Having then set up correctly and tuned perfectly make the difference). My 2 cents worth and preference.
Josh
Diesel Cub Cadets...........
Old 05-05-2014, 11:30 AM
I like the ability of a longer reach of a Haban 60 under fence and trees....never understood the reasoning of a 50" on a Super....If it can carry it run it.
Old 05-05-2014, 02:12 PM
Sort of how I feel about anything less than a 48" on the 1X6/7 and 1X4/5 series tractors.
Old 05-05-2014, 02:34 PM
red56turbo's Avatar
I agree on the bigger decks. My CC zero turn has a 60 inch deck on it and it mows great in the wide open spaces.
But, I also have a wind break planted and buildings to mow around. The 60 inch deck is too big for these areas. I know some guys/gals have gates to go through and the 60 inchers prolly wouldn't fit. So each sized deck has its place.
On a side note, I've seen some of the older 38 inch cast iron end decks on 70's and 100's do one heck of a nice job mowing, too. All depends on the setup of the deck and sharpness of the blades.
Josh
