Old 05-05-2014, 06:48 AM
Tony h's Avatar
Tony h Tony h is offline
Default Oil Plug KT17 engine
Changing the oil for the second time since I acquired my 782.
I look at the Plug and I think, 'That aint right' . The plug on my tractor is a Brass Tapered threaded Plug. Can someone tell me if there should be a standard type plug that has a Crush washer or is this Brass NPT plug what they did on this engine?
If I can't fix it , it must not be broken
Old 05-05-2014, 09:16 AM
That is NOT OEM.
Old 05-05-2014, 09:55 AM
That is NOT OEM.
I agree, but a brass plug should be fine. The OEM is a pipe plug, so as long as it's tight and doesn't leak, it's fine. Personally, I wouldn't use brass..... but mainly because a brass plug costs like 3X what a steel plug would.
That engine should not have a drain plug in it like a car, with the washer you refer to. All the PO did was replace (a probably worn) drain plug with a brass one. Unless it isn't tight, leave it, it's fine. The OEM plug had a hex head, but it was just a pipe plug.
Old 05-05-2014, 04:41 PM
Tony h's Avatar
Perfect. thanks for enforcing the message that the OEM WAS a Pipe plug. That gives me comfort that the PO didn't mangle the threads. Great... nothing to fix here.
