Hello all, its been awhile since I've been on here, too busy working on other IH projects and farming!!!.
I have a 25hp Briggs and Stratton vertical shaft engine out of a newer plastic junk cub cadet that is basically scrap now. The engine is in great shape and I wonder if I could do a cool re-power in a Cub Cadet!!! I have three Cub Cadet that could be recipients of this motor. They are a 107, 1200, and a 1711. I wonder if I could run a belt from the engine to a 90 degree gearbox that would be attached to the tranny input shaft. I think this might work but I'd like advice on how to accomplish this. Id like to spend as little money on this as possible while doing it right. Thanks for any input!
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
Now why would you do something like that?........
![]() Not that I'm a purist, but if you want to do a re-power at least keep it a shaft drive.
The only reason Id like to do this is because I already have this engine and I'd hate to scrap a good motor...
I'd hate to see a tractor modified for that.....
Go find you a regular old run-of-mill mower with a bad motor. You can pick them up for $50. Put the motor in it, sell it, then take the money and go buy a K series and put that back in. Then you don't scrap a motor, and you get a cub up and running the right way. Where you at in Illinois? |
Get a CC lawn tractor, easy swap being belt drive, imagine a 25hp 76 or a 1330 swapped (but I'd go gear drive not hydro) or even better an IH rear engine rider modified to fit the big twin
122 PTO, lift, deck, weights, and chains clist pick 123 headlights no motor came with the 122 Stx38 free acquisition but its the wrong color works great though Free craftsman gt 17hp Briggs Intek hydro |
I think you could do it with very little permanent mods. So if you have the time...
Good to read from you again! I have seen much of your work, and it is very neat!
I would think what you would be doing is having a set up similar to what is fount on the IH Cub Cadet 1100, and 582 Special..... only using the input shaft as you mention. You might have to cut out and weld the narrow frame tractor a bit. I think the wide frame 1200 would be a good bet. Power transfer with a IH 90* gear box to the input shaft. This would be neat to see the out come of such a re-power! If anybody on this forum can do anything, it would be you! Good luck! |
I have actually considered doing that conversion my self, as I have a sweet running VS Brigs 18 flat head twin. My 149 had a mod, smaller engine when I got it.
Steve |
Just curious if you've considered the B+S twin vertical/horizontal conversion? ... Im assuming you CC experts know more about that than I do but Ive been reading about it because I have a 14hp Vanguard twin I dont know what Im gonna do with?
Lance / Alberta Can IH 127 w/deck, snowblade IH 154 Loboy(x2) w/creeper 3pt and 3160 deck CCC 12.5 w/deck Plus 35 or so non IH tractors |
That 25 horse on a push mower would be something else, I could mow my hedges.
Philip 1450, 1015, and a pile of parts. |
