Old 05-20-2014, 02:33 AM
lynco's Avatar
lynco lynco is offline
Unhappy Battery won't charge
Old 109 running well but the battery doesn't seem to be charging... and it's a brand new battery. Any ideas ?
Old 05-20-2014, 07:11 AM
Check out the Charging System. It is either the Starter/Generator, Voltage Regulator, or some wiring issue. See.... Test
Old 05-20-2014, 07:52 AM
lynco's Avatar
Thanks Roland. I'll give it a try tonight.
Bill
Old 05-20-2014, 09:51 PM
gmbadgley gmbadgley is offline
New battery?? They did fill it, right? Check all of the connections also.
Greg
"If I can't fix it, I can screw it up so bad no one else can either"
Old 05-21-2014, 12:50 PM
lynco's Avatar
To Roland:
I did the continuity check, both wires are good. It took a while to figure out what wires were what as there really are no distinguishable colors. but I found out what they are using a wiring diagram I found on the internet a while ago that I just noticed was submitted by a "R. Bedell". Great diagram ! I've seen a few and yours was easiest to read and looks true. I ordered a new V/R, I'm pretty sure that's it. I don't think the S/G is bad because I put a different one on that was in working order and still was not getting a charge. I'll let you know if the new V/R works. Thanks again.
Greg: if you're reading this... it is a new battery, filled and fully charged and my connections are all good. thank you also for the input, by the way your signature quote sounds like it should go under my name.
Bill
Old 05-21-2014, 12:58 PM
Roland's diagrams are in our "tech" section here on the site under "Technical Library-Tractors".
Old 05-21-2014, 01:00 PM
Shaner Shaner is offline
Don't forget to polorize your new regulator before starting your tractor!
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 05-21-2014, 08:38 PM
lynco's Avatar
Thanks for warning me about Re-polarizing... I didn't know. I'm reading how to in the test Rouland suggested above. Am I reading it right? A short jumper between the B & G terminals on the V/R ?
Old 05-21-2014, 08:44 PM
DarwinsFlinch's Avatar
DarwinsFlinch DarwinsFlinch is offline
Does a VR that has been completely removed from a tractor need to be re-polarized?
Single Cub owner: 129 1/2 (129 w/14 HP)
Old 05-21-2014, 09:57 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
It is actually the generator that is being polarized. Any time the battery, V/R, or S/G is disconnected the generator needs to be polarized.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
