Old 06-08-2014, 03:53 PM
Fitz14's Avatar
Fitz14 Fitz14 is offline
Default Cub 982
I'm trying to figure out which engine I have in my 982 I just bought. It's supposed to have a 19.9 hp B48G Onan. However the tag on the shroud says B43G which is 18 hp. The serial number on the tag does not match the serial number stamped on the engine block. I assume somebody put a different shroud on it. Maybe a different engine too. The air cleaner is from a P218G and doesn't even fit. Is there a place where I could find out what I have by matching the serial # from the block? Thanks
Old 06-08-2014, 06:10 PM
You could try here: www.onanparts.com
Old 06-08-2014, 10:16 PM
john hall's Avatar
chasing info on Onans can be a bit sketchy somedays. I gave one of the online Onan dealers all my info and he couldn't come up with an air filter, go figure. Whats the chance you are reading the tag wrong, mine isn't stamped the best but it reads B48G-GA019.97370B. The way I understand it the B48G is the model, GA019.9 is the HP and the 7370B is the spec. Recheck your numbers and give one of the online Onan dealers a call and see if they can tell you if air shrouds will interchange between the 2 models---I haven't been able to locate ANY online parts books for my Onan.
