Old 06-10-2014, 05:04 PM
unit91's Avatar
unit91 unit91 is offline
Question Front Wheel Zerks
Can't get my grease gun to lock onto these front zerks. What can I do?
Old 06-10-2014, 05:25 PM
rfrank's Avatar
rfrank rfrank is offline
Try a different grease gun. If that wont stick and the zerks are clean, then replace the zerks. I had a deuce and ahalf in the service that had 55 zerk fittings. I found that the greasegun quality and the wear of the grease gun "female end". Played a big part.
Old 06-11-2014, 12:27 AM
unit91's Avatar
Default front wheel zerks
What I meant to say was that there's not enough room between the zerk and the wheel to allow my grease gun end to fit in there. The zerk is straight. Do they make angled zerks?
Old 06-11-2014, 12:29 AM
Yes, and they also make a right angle end for a grease gun.
Old 06-11-2014, 04:36 PM
unit91's Avatar
Red face
OK, good! I'm gonna look for both. Thanks.
Old 06-26-2014, 07:20 PM
unit91's Avatar
I've checked all area car parts stores and can't find any angled zerks or angled grease gun ends. Anyone know of any online source I might try?
Old 06-26-2014, 09:42 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
NAPA
TSC
Farm Store
or any decent auto parts store with the orange steel cabinet of "Dorman" products.
Old 06-27-2014, 04:51 PM
unit91's Avatar
That's where I went - auto zone, napa, farm tractor. they all had angled zerks but not long enough. the cub cadet zerks have a long neck that screws into the wheel, so the standard short zerks won't work.
Old 06-27-2014, 05:13 PM
Will it hit something? I find it hard to believe that this grease zerk is so special that a short one won't work or that you can't find a replacement.
What tractor is this on?
Did you try Cub Cadet?
How about a picture......
Old 06-27-2014, 05:30 PM
How about a pic of what you have. I find it hard to believe that you can't get a standard gun on these fittings. I've never had a problem using a regular gun to grease the wheel bearing fittings.
