Old 06-14-2014, 12:16 AM
dsmall dsmall is offline
Default Just bought an 882
Hey everyone I just entered the Cub Cadet world by buying an 882. I didn't even know what I had until after I bought it. I was just looking for a durable replacement tractor for my old snapper. I did a search for a diesel garden tractor and this was what I found. It was one of the only ones less than 2k.
The tractor was inherited from the original owner/father and the guy was moving to Florida so he didn't need it anymore.
The tractor was rough but mechanically sound. When I went to see it the guy could barely get it to start. The radiator had a crack at the upper neck and there was a leak at the thermostat cover. All that helped the price drop and I knew I could fix it. The guy was not mechanical. Bottom line was he dropped his price way below what he was asking... score!!!
The tractor is rough but I'm cleaning it up and everything mechanical is fixed.
Now I'm just cosmetic stuff to fix.
Old 06-14-2014, 06:41 AM
mickb72 mickb72 is offline
Welcome to OCC. Congrats on the D 882. Where are you in Ohio? Mike
Old 06-14-2014, 09:08 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 06-14-2014, 09:53 AM
Welcome to OCC! Glad to have you! I'd love to find a smoker!
Old 06-15-2014, 09:14 AM
Welcome to OCC!
Pics would be awesome!
Old 04-01-2016, 02:46 PM
Just outside Oxford. Small college town about halfway between Cincinnati and Dayton.
Old 04-01-2016, 02:55 PM
Sorry for the late reply everyone. After I bought the tractor I had lots of trouble with it. Starting and grounding issues mostly. VERY FRUSTRATING! Then issues with the deck spindles and lots of burned up belts. I replaced the starter with a gear reduction unit and then replaced the whole deck. It runs well but now I'm having issues with the PTO. Still have starting issues because I need a bigger better battery. Doing research now and I'll let everyone know what I find that fits.
Old 04-01-2016, 05:33 PM
scarps68's Avatar
scarps68 scarps68 is offline
dsmall I too bought an 882 last year and didn't realize how well I lucked out. Good luck with yours!
FYI I replaced the battery with an Interstate SP40. No problems turning over now.
Don
882D
50" Deck Mower
54" Snow Dozer Blade
Agri-Fab Lawn Sweep
Old 04-01-2016, 09:46 PM
Scarps68 I noticed your side panels are gone. Did you remove them for overheating reasons or were they missing when you purchased it? Have you updated the starter with a gear reduction unit? That was the first ugrade I did. The steering is stiff so I'm considering a heavy duty tie rod replacemet kit and Super Steer upgrade from Kirk Engines Inc. I still have some stuff to fix. Here is a list of what still needs to be done.
Original fuel filter assembly was missing so I have a new one on order.
One of the engine mounting plates is broken so that is next on the list.
The rubber isolators in the drive shaft are shot so those need to be replaced.
And finally the flange bearing plate is shot so it needs to be replaced.
Old 04-02-2016, 10:22 AM
longislandcubs longislandcubs is offline
I really have enjoyed my 882D. I replaced my starter with a high output as recommended by a forum thread I had read. Big difference. Good luck with yours.
