Old 06-17-2014, 07:41 PM
druwl druwl is offline
Question 44 deck pulley removal
Everything looks decent considering.... except for this one pulley. "Ther's yer problem lady ret ther!" lol
So I got the top nut off, but the bottom nut ain't moving. I checked the diagram and it seems to show the pulley and the nut as one piece? So how do I get a puller on it without taking out the grease zerk? <Maybe that's the ticket?
1975 IH CC 1250
Always looking for pre '65 dimes, quarters and half dollars to purchase.
Old 06-17-2014, 07:45 PM
thehud thehud is offline
The nut is part of the pulley.
If by chance the grease fitting is threaded, you can remove it. But I typically put a socket over the fitting for the puller to rest in and keep it off the fitting. And as bad as that pulley is, you may have to consider doing a little careful cutting if it isn't easily convinced to come off.
Old 06-17-2014, 08:11 PM
Good Grief!!! Where was that thing, on the Titanic???
Old 06-17-2014, 08:18 PM
The weird part is the other pulleys look really good! It's like a family of metal termites took vengeance on just this one.
1975 IH CC 1250
Old 06-17-2014, 10:52 PM
The "nut" does not screw off, it should (along with the pulley) slip off.
As "Thehud" said, put an old socket on the end of the shaft (but not one that will get into the threads) and strike it (the socket) SHARPLY with a hammer, that may jar the pulley loose from the shaft.
Old 06-18-2014, 12:14 AM
Holy Toledo, I ain't ever seen a pulley rusted up that bad.
Old 06-18-2014, 02:39 AM
I don't think I'd try pulling it for very long before I just cut it off.
Old 06-18-2014, 07:32 AM
My humble 1/50th of $1....
Try heating that pulley/shaft junction with a torch, then while still hot SOAK it with good penetrating oil (PBBlaster Kroil, etc)
May need to do that a couple of times. Also, use the heat & penetrating oil bath on the lower nut. Had to do that to get the spindles off my 38A deck last winter.
If I recall correctly, both the blade nut and the nut that is part of the pulley are 1-1/8". If you don't have an impact driver, use a LONG wrench and breaker bar on the socket.
(Where is that red-faced " uh-oh...I just popped a hernia" smiley when you need it?)
Only thing better than having a Cub Cadet is USING one
Old 06-18-2014, 07:45 AM
Just a word of caution here....
If yer gonna beat on it, use a brass drift and not something hard so you won't screw up the treads on the shaft!!!
Old 06-18-2014, 10:30 AM
Nitro's Avatar
Nitro Nitro is offline
Might be that I'm a mechanic, but my very first thought was "Acetylene".
Philip
1450, 1015, and a pile of parts.
