Old 06-22-2014, 11:10 AM
Bumpy55 Bumpy55 is offline
Default 1450 Running Rough
While mowing yesterday my 1450 started popping and running badly. Found if I pulled out the choke halfway it would run well enough to finish mowing. What should I go look for to get this running good again. Thanks for the help.
Old 06-22-2014, 11:22 AM
The first thing I would do is check the fuel lines for proper flow. Second would be to check the float.
Old 06-22-2014, 11:50 AM
C.I.C. Crap In Carb would be my guess.
Old 06-22-2014, 09:03 PM
most-basic most-basic is offline
the best guess i have is to check your lines clean your carb then run lots of fuel treatments through it after you clear the carb.. but only use as much as the bottle says... i would use sea foam the most, but after u get her running good again buy a whole big bottle of lucas fuel system treatment put some of that in there every time u fill up for the best results.
keep us posted
Old 06-23-2014, 01:02 AM
keep us posted
I don't recommend a constant barrage of fuel system treatments. 1.) Unnecessary/ waste of $$. 2.) There is such a thing as "too much of a good thing" It can foul plugs. 3.) It's not necessary. Oh, and did I mention it's not necessary?
Old 06-23-2014, 08:01 AM
Yeah i don't see what those fuel additives do either besides wasting $$.
