Old 06-23-2014, 08:00 PM
garth68 garth68 is offline
Default 582 restore
well start my 582 loader/restore this weekend got most of her apart. the po told me the rear end was gone over last year and i didnt quite believe him but turns out i was wrong every thing was new or in good shape.so thats one less thing i need to do motor is in good shape it runs just need to find some head gaskets any help there? clutch is done so will have to restore that but over all shes in good shape oh one last thing cant figure what year it is will post vin tag if any one can help
Old 06-23-2014, 08:25 PM
bocephus1991's Avatar
Believe that's a September 1980
Brian
Old 06-23-2014, 09:48 PM
Yep, it was built in September of 80. Good luck with your 582.
Old 06-24-2014, 04:47 AM
BCDSFCRET BCDSFCRET is offline
Default Bcdsfcret
Did you actually take the engine out without taking out the front grill housing and the engine plate? If you did you made the whole job ten times harder.
Keep up the good work! There are not tons of 582s around.
Brian
Old 06-24-2014, 06:36 PM
Brian
thanks curious why not taking the grill off and the motor plate out makes it harder?
Old 06-24-2014, 07:13 PM
Default Bcdsfcret
front grill housing 4 bolts. Housing and hood come off
6 bolts from the bottom of frame engine comes out with plate. 30 minutes to get engine out and on bench.
Brian
