Old 06-24-2014, 05:06 PM
nikster's Avatar
nikster nikster is offline
Default Welding advice ?
Expert advice needed!
A friend of mine needs a bolt welded onto his tire carrier. Naturally it's mounted on the tail gate & swings out to open the cargo area.
I heard that by connecting the negative ground to the vehicle & welding on the vehicle (tire rack) one can damage the computer on the vehicle?
I'm reluctant to do this simple task until a get a positive yes or no.
Can the computer of the vehicle be damaged?
NIK,
Thanks.
Old 06-24-2014, 05:15 PM
I work in a collision shop so i weld on cars daily and thats mostly a bunch of bs. The power will go straight from the torch to the ground so unless you put the ground on the other end of the car you'll be fine.
Old 06-24-2014, 05:48 PM
Agreed. Ground it close to where your working.
Old 06-24-2014, 05:59 PM
Shaner Shaner is offline
I've heard of it happening. Just disconnect the battery to the vehicle first to avoid any worry.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 06-24-2014, 08:00 PM
Exactly, why take chances when you can disconnect the battery in a few minutes.
Old 06-24-2014, 08:04 PM
I've urban legend I've heard plenty of times is that even with the battery disconnected the computer can be damaged. I never actually seen it happen and call BS to the entire notion. The power is going to take the shortest path to ground which is not going to be through the computer. Disconnect the battery and weld away.
Old 06-24-2014, 08:12 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Make it mandatory! Disconnect the battery! No chances! Had problems with MSD systems in race car even grounding the welder close to source of weld. Lessons learn! Same goes for battery charger on battery. Disconnect!
Plow blade
#2 Cart
QA36 snowthower
Old 06-24-2014, 08:19 PM
Arc, heliarc/tig welding is all based on electrical current. When you learn about electricity, it's referred to as electrical THEORY.
Electricity usually does what you have learned but sometimes it has a mind of it's own. Yes, it usually takes the shortest path but no guarantees
Old 06-24-2014, 09:08 PM
mrmiller mrmiller is offline
I do a lot of welding on heavy truck frames for mounting bulk hoppers at work and always unhook the battery before doing any welding....yet to have any problems. It is something we always do anyway but usually the customers request the battery to be unhooked.
Old 06-24-2014, 10:24 PM
nikster's Avatar
Thanks to EVERYONE!
Nik
