Old 06-25-2014, 02:49 PM
Steve149's Avatar
Steve149 Steve149 is offline
Default Hydro Question
This is my first run at a tractor with Hydrostatic drive a 149 and I guess I am just used to gears. I have noticed that when I start out going forward at a slow speed after moving for a few feet the tractor seems to take off faster without moving the control lever. Has anyone experienced this? What is the cause and how to correct is good information to know!
New to the cub cadet world and loving every minute of it!
Old 06-25-2014, 02:54 PM
Shaner Shaner is offline
the trunnion on the hydro pump is probably worn out. its an easy fix. all you have to do is pull the rear fender pan, and find the square piece with the two springs and endcaps on them. most of the time, those end caps wear out two grooves in the outer edge of that square bracket. this will cause your hydro to be jumpy. if you want to fix it the right way, take that bracket off, remove the springs, build up the worn grooves with weld then file away till they are true again. but, if your looking for a quick down and dirty fix that WORKS, weld some key stock ontop of the existing square piece. it will cover the grooves and keep the springs and endcaps from moving. it works. i use the keystock method on all my worn out trunnion tractors because its way easier.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
tservice tservice is offline
This will help. It is a very common problem.
http://www.onlycubcadets.net/forum/s...ighlight=lurch
Old 06-25-2014, 02:55 PM
What model of tractor are you referencing...???
im guessing a 149
Old 06-25-2014, 04:20 PM
You could look at the "friction disk" that applies friction to the lever handle linkage, so that it stays where you put it, also.
Old 06-25-2014, 04:27 PM
Steve149's Avatar
yes that will be looked at as well but I think the trunion is worn if I remember the other day poking around I noticed that it looked like it was worn out a bit iwill look at this tonight to verify
Old 06-26-2014, 09:02 AM
sawdustdad's Avatar
When the tractor accelerates wildly on level ground, it's due to a loose friction control on the hydro lever. When speed varies dramatically going up and down hills, it's usually weak springs or wear on the trunnion.
At least that's been my experience, limited though it may be.
