Old 06-26-2014, 08:01 PM
larry03061976's Avatar
larry03061976 larry03061976 is offline
Default Which one?
Ok, the belt chart shows 2 belts for my 125. Measuring it is out since it is in three pieces. Any way else to tell which one is correct? Also, somewhere I saw a post saying there are two different mule drives, one for mowing and one for snow blowers. Does any one have the link to this discussion? Thanks in advance.
Old 06-26-2014, 08:09 PM
Exactly what belt do you need? ( mower drive belt? )
I use the same mule drive for mowing and roto tilling on my 125s. My QA 42 snow thrower quick attach mount uses a short belt to drive the gear box.
Old 06-26-2014, 08:13 PM
What is your deck size? If you have 38 or 42 you need an 81" belt
Old 06-26-2014, 08:15 PM
Its a 48 and I need the one from the pto to the deck.
Old 06-26-2014, 08:49 PM
Not sure where you get your information, but I only see one belt for the 48" deck in the belt chart.
Old 06-26-2014, 08:52 PM
If not mistaken it shows a 3/8x75 1/2 and a 1/2x80.
Old 06-26-2014, 08:56 PM
It shows a 3/8x75 1/2 and a 1/2x80. Not sure which is which.
Old 06-26-2014, 08:59 PM
Awhile ago somewhere there was a thread about one mule drive had angled pulleys and one had straight pulleys. Someone said one was for the mower and one was for the blower. Just wondering if this is the reason it eats a belt evry year.
Old 06-26-2014, 09:07 PM
The 1/2" X 80" belt is the deck belt, for the spindles...
Old 06-26-2014, 09:37 PM
cadzag72 cadzag72 is offline
Blower doesn't need a mule drive, the pulley for it is in line with the PTO, no fun angles to bend around. You want the 3/8x 75 1/2 belt. Best of luck!
Ian
