So picked these AG tires up off CL for pretty cheap, but they have overspray on the tires. I was going to use lacquer thinner to try to get it off, but thought you guys might have another/better way. I don't want to damage the tires in the process.
Hit the detailing shop and grab a can of tire paint. (yes they do make it)
Greg
"If I can't fix it, I can screw it up so bad no one else can either" |
Acetone......??????
Ive had good luck with brake cleaner getting paint off tires, spray it on the rag not the tire or you might take the paint off the wheels.
Super Kleen (available in Wal-Mart, purple container for about $7). It will remove grass grime, dirt, grease, paint, etc and I have never had any damage on my tires from it. Wear googles and latex gloves as it will remove the oil off of your skin, too!
I haven't tried it on tires yet, but PB Blaster removed my overspray on my lift arm. Cub Cadet 123
If you have a sandblaster a light dusting will take it right off. It will also take off the dull layer leaving the tire nice and black.
I like to keep em running and work them. 1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors. |
If you can't get it off, Miller tire paint is some good stuff! I just painted some old tires to cover over spray from the previous owner, covered great and made the tires look pretty good. It is a concentrated paint, a little jug goes a long way!
Good luck,
David |
Goof off the acetone stuff.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Lacquer thinner will take it right off with no damage to the tire.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
The only success I've ever had is mechanical removal. 3M scotchbrite grade "VFN" (very fine) roloc wheels will buzz it right off and won't take the rubber if you're quick.
It may just be my poor luck that most of the above suggestions haven't worked for me. Sandblasting DOES work but has obvious down sides. |
