Old 06-29-2014, 05:58 PM
Default Easiest way to remove 1650 driveshaft
Take out the engine or?
Old 06-29-2014, 06:39 PM
Use a hacksaw.hehe
now you know the answer is to look in the manual .
Maybe someone else can chime in and help you out if you do not want to go that route.
Old 06-29-2014, 06:44 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Use a hacksaw.hehe
Torch or plasma cutter would be faster!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 06-29-2014, 07:03 PM
Use a hacksaw.hehe
I don't find it in the manual.
There's an easy way and a hard way. I just can't remember which way is which.
I have bought tractors that appeared to have been worked on by jokers like you two.
Old 06-29-2014, 09:26 PM
I think pulling the rear is easier than pulling the engine. It's a matter of personal option.
Old 06-29-2014, 09:53 PM
FWIW.
I knocked the pins out of the rear coupler to the pump. Slid the coupler and fan forward on the shaft and lifted the driveshaft straight up and out.
Old 06-29-2014, 09:55 PM
That is how I do it!!
Old 06-29-2014, 10:06 PM
timbo2's Avatar
timbo2 timbo2 is offline
sounds like you did it like this:
http://cubfaq.com/qldriveshaft.html
I'll be doing it on my 1450 one of these days. I need to replace the fan and will do rag joints while I'm in there.
- Tim
Old 06-29-2014, 10:13 PM
Ditto.......
Old 06-30-2014, 12:17 AM
jimbob200521's Avatar
I was going to go with angle grinder
I'd slide the engine forward if I couldn't finagle it out otherwise.
-Ryan
