how hard is it to change your own ft tires? my 70 has brand new lug rear tires but i wanna put some tri rib tires on the ft. what tools do i need? how hard is it? thanks.
It's easy. All you need are a couple of tire irons.
The smaller the tires, the harder they are to change.
I always use three large screw drivers, be careful not to pinch the tube anywhere, cause you'll pinch a hole right in it. |
I'm tempted to make a video tutorial for changing tires with tire irons when I'm home for spring break in a week and a half, since it seems to be such a lost art...
Matt-
That sounds like a very good idea with the tutorial. I've been paying to have mine done but at $10 a pop (which includes a tube) it can get expensive. I'm considering one of those Harbor Freight changers and they just went up to $45. If I'm right they will be on sale again next month for $39.95; at least that's what I'm hoping for. The reason I have them done is I tried a couple that had fix-a-flat in them and that's some nasty stuff. It gets all over everything. I have also experienced the ole screwdriver through the tube bit as well. You never know until you're back working and the tire you just fixed is low on air once again. Ugh! |
For my dirtbike tires I use 2 tire irons and little tire clips the keep the tire to go back into the rim. For front tires it should be pretty easy
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
I change my own tires, maybe it is a lost art Matt.
I use my 20 ton press to break the bead, takes the work out of it, the rest is...easy. I'll tell you though I've had a couple that were difficult as the 20 year old rubber becomes hard some are rusted to the rim. Scott |
Scott-
Yeah, the rusty ones are the worst, particularly wide front rims because the diameter stays the same on one side over such a great distance, it's really hard to get the 40-year-old rock-hard tire to slide over a rusty surface. Still doable though, as you'll probably agree. |
i use a 2x6 to break the beads, lay tire on the ground put the 2x6 on top of tire , but not on rim, then use the truck and slowely drive up the 2x6 and the bead will brake loose. use a little dish soap and water to help slide tire off the rim. use 2 large screew drivers
I used an old leaf spring and drove up on it with my pickup. Worked great.
I bought a set of tire irons at a local motorcycle shop. On my way home that same day, I stopped at an estate sale and found another tire iron. You can never have too many. On my fronts, when I got the bead down in the channel, I used a quick-grip to hold it there while I walked the tire around the rim. Otherwise, it keeps wanting to pop back up. I want to see your video Matt. I always like to learn. I think the hardest part about the small tires was wrestling them around on the bench. You just can't get a good hold of them!
--------------------- Jim in Lafayette, CO Cub Cadet 122, 126 |
