Old 07-20-2014, 07:04 PM
saltybrook saltybrook is offline
Default 1964 cub lo-boy hydraulics and transmission/gear box
Hello- There is a check port behind the shifter {square head plug}. How full should it be? also, should the hydraulic reservoir have fluid flush to the bottom of the filler plug hole?
Thanks you guys-
Old 07-20-2014, 09:05 PM
Farmall Cub's are better suited on this forum..... http://farmallcub.com/phpBB2/viewforum.php?f=2
Old 07-20-2014, 09:10 PM
There is a fill line plug on the side of the trans. Left hand side.
Thanks you guys-
Yes. Doesn't have to be perfect. I usually fill till it runs out, install the plug and add just a tad more.
Tags
lo-boy
