Old 07-21-2014, 08:02 AM
rebel715 rebel715 is offline
Default Steering Wheel Removal??
I am getting some play in my steering, and wanted to pull the steering column to adjust the play. I am unable to remove the wheel after removing the nut. Is there a special puller I need to remove this?
Thanks!! My tractor is a 1977 IH Cub Cadet 1000.
Old 07-21-2014, 08:57 AM
Do a search "steering wheel removal" and you see about 2 pages of few threads on the topic.
Old 07-21-2014, 10:03 AM
sawdustdad's Avatar
You can make follower stud adjustments with the gear box in place if that's what you need to do. No need to pull the column out unless you are rebuilding it.
Old 07-21-2014, 11:05 AM
I usually just loosen the nut, spray it with penetrating oil, and put my knees under the wheel and pull up while hitting the nut with a hammer and a piece of brass, if that doesn't work, I do the same thing except this time I put a puller on it and tighten it down good, has worked for me every time.
Old 07-21-2014, 11:25 AM
I did one yesterday , partially remove the nut and then I used the knees and one hand to pull up on the wheel, then with the air hammer tool, pops off every time.
Old 07-21-2014, 11:44 AM
link no worki for me....
Just did the same thing on my 682 and 1250,I used a bearing puller tool and a 3 jaw puller, tightened it down and it popped right off.
Old 07-21-2014, 11:48 AM
Shaner Shaner is offline
guess i got lucky with my 782. got the nut off and the steering wheel lifted off with no effort. the knees under the wheel and tapping the nut with a hammer trick does work good! just make sure you aren't hitting the threads of the steering shaft.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 07-21-2014, 12:59 PM
No idea why it no longer works. I edited my post to do a for search for steering wheel removal
Old 07-21-2014, 01:20 PM
red56turbo's Avatar
Both Lew and Nick have great ideas. I now prefer Lew's method with the air chisel. Quicker and I have an air chisel to use. If ya don't have one available, soak it with a good penetrating oil and she will come loose.
Josh
Diesel Cub Cadets...........
Old 07-22-2014, 02:34 AM
Rdrnek Rdrnek is offline
I always use a puller. they are really cheap at HF tools.
-Bob-
149 w/48"deck, 2 100s and and 2 ugly "O"s parts 104
